#27150 11/07/04 02:19 PM
Ger13 Offline OP
Hay Guys,
Just a quick questions. Is my 1940 Chevy grill stainless steel or is this something I need to have chromed?
My grill has some surface rust, which makes me think it must have been chrome. Stainless steel will not rust, is that correct?
Thanks,
Gerry
Gerry
VCCA #37909
www.1940chevrolet.info
#27151 11/07/04 02:32 PM
Gerry---yes it was chromed ,mine was the same way with surface rust --it ain't cheap to get it recromed !!You may want to consider powder coating ( in "chrome" paint )it until the cookie jar has enough to do a chrome job properly
john
#27152 11/07/04 05:45 PM
Ger13 Offline OP
Thanks John,
Oh well, it just money. If I had wanted a cheep hobby I could have choosen bowling. You get to the point after spending so much, . . . . I may as well do it right.
If and when I do the chrome, it appears there are rivits holding on the bottom front panel, would they need to be cut to remove the grill?
I will remind my wife that my birthday is coming and a new grill would be a perfect gift.
Thanks again.
Gerry
VCCA #37909
#27153 11/09/04 06:27 AM
Gerry
Best of luck with new grille for your birthday but be sure you specify grille for the chev and not a grille for the bbq.
