Posts: 50 |
Hi, Does anyone know what the correct color scheme on the parking brake handle is supposed to be. Its a 1938 Master Deluxe model HA. Any help would be appreciated.
Posts: 7,046 Likes: 107
Posts: 7,046 Likes: 107 |
Judging by what paint is left on mine I'd say it's Plover Beige. It looks rusty but that's just well worn paint. ![[Linked Image from i47.photobucket.com]](http://i47.photobucket.com/albums/f167/Tinys1938/IMG_0177s.jpg)
Posts: 434 Likes: 1
Posts: 434 Likes: 1 |
Tiny's correct--Plover Beige, the accent color on the dash and elswhere.
Posts: 50 |
Thanks for the info, but isn't the small squeeze handle chrome by itself?
Posts: 4,446 |
![[Linked Image from i1302.photobucket.com]](http://i1302.photobucket.com/albums/ag124/wawuzit/100_2785_zps0bd9c138.jpg) The push in handle is low grade stainless steel( maybe 304L). The handbrake extension is chrome. ![[Linked Image from i1302.photobucket.com]](http://i1302.photobucket.com/albums/ag124/wawuzit/last6.jpg)
Posts: 724 |
Speaking of the handbrake lever..has anyone ever tried successfully to remove the two stainless rivets holding the brake lever so the lever can be refinished? and successfully installed a new set of rivets so it looks original? I'm not sure how they bucked the rivets originally...looks like they had a machine that did it....doesn't look like a normal bucked rivet..I've got a brake lever assembly that had them removed and someone tapped one end of the rivets to hold them in...and that's exactly what it looks like!...doesn't look original at all...Billu38
Posts: 4,446 |
![[Linked Image from i1302.photobucket.com]](http://i1302.photobucket.com/albums/ag124/wawuzit/999999999_zpsb9954732.jpg) ![[Linked Image from i1302.photobucket.com]](http://i1302.photobucket.com/albums/ag124/wawuzit/99_zps931f5f00.jpg) I polished mine up as best I could. If you're going to take it all apart...go chrome !! smiles
