#270191 02/10/13 08:13 PM
holtzie Offline OP
I'm trying to put my '32 horns together and i'm not sure how they go??? Also what side of the terminal pos.
frankie
holtzie #270357 02/12/13 02:24 PM
A little more explanation may help you to get the information you need.Did you take them apart or are you looking for installation information?
m006840 #270431 02/12/13 11:48 PM
holtzie Offline OP
I'm trying to put the bases on the trumpets and there is a center piece with a stud sticking out, does that go against the electrical solindoid?
holtzie #270436 02/13/13 12:30 AM
I think you are confusing the electromagnet for a solenoid. There is a small off centered stud on the back of the vibrator (wavy sheet metal disc with threaded stud and nut that holds on a smaller plate). The small stud needs to contact the round insulated paddle. That is what switches the electromagnet off and on making the disc vibrate and make noise.
Chipper #270479 02/13/13 02:11 PM
holtzie Offline OP
Is there any adjustments? I try it that way and the horn just clicked?
Does it make a difference on the wire hookup?
Thanks,
Frankie
holtzie #270509 02/13/13 08:15 PM
There is a slotted adjustment stud on the back with a lock nut. Loosen the nut and try moving the stud one way or the other. Was the horn working prior to taking it apart?
holtzie #270534 02/13/13 10:16 PM
If you have a VOM or ohm meter, adjust the screw on the back so that there is only the slightest contact. That should make a contact to retract the disc when the electromagnet is energized and get the disc vibrating. Slight adjustments will finally get a loud vibration.
Chipper #270571 02/14/13 09:21 AM
holtzie Offline OP
Thanks for the info
