Posts: 5 |
I have a 32 BA confederate deluxe convertible. At around 25 / 30 mph the front shimmies like it's going to fall off. My rims and tires have been balanced and all tie rods are fine. Anyone have an idea what's going on
Posts: 7,046 Likes: 107
Posts: 7,046 Likes: 107 |
Turned out to be shocks on my '38. I even had my single acting lever shocks rebuilt but it didn't completely stop it. I ended up converting to tube type shocks, problem solved.
Posts: 415 |
Tiny, Do you have the straight axel on your car,or the knee action type shocks? ___________________________ Joe's 37
Posts: 5 |
Tiny, Do you have the straight axel on your car,or the knee action type shocks? ___________________________ Joe's 37 Straight axle.
Posts: 292 |
Check your king pins if not loose check the steering box for play one or the other is the problem. Al
Posts: 1,213 Likes: 1
Posts: 1,213 Likes: 1 |
Sounds like a wheel alignment or sagging front spring problem.Have you had the toe in,caster & camber checked? Wheel alignment data for a '32 is as follows:
Caster: 2 1/4 degrees positive
Camber: 1 1/2 degrees positive
Toe in: 1/16" - 3/16"
Car to be loaded with a fuel tank of petrol(gas)
CJP'S 29
