Posts: 48 |
Does anyone have pixs and measurements of the 1933 Master Closed car flip down inside visors, also of the mounting/pivot hardware? Do they also rotate to the side? i have some hardware just trying to ID and organize and probally going to cut a pc of masonite for visor base. Thanks in advance for any help.
Posts: 48 |
At this point all i really need is the measurements of the 'hard cardboard' flip down visor on a 1933 Chevy Master Closed car...Coupe or Sedan. I can sort out the hardware i have and find some that will work. Can anyone take a quick measurement for me? Length and width...i have a small leftover corner chunk so i can get the radius of the corners fairly close. Thanks in advance.
Posts: 3,163 |
Did you get the picture you needed?...Joe
Posts: 48 |
Still hoping for measurements from a 1933 Chevy Master Closed Car Inside Sun Visor. Need the size of the 'hard cardboard' Some of my hardware is just flip-down some is flip and pivot...so i must use imagination and improvise to make a set...didnt see any pixs yet but just really need the msmts. thanks in advance.
Posts: 3,163 |
Give me an e-mail address & I'll take some pictures & measure it for you tomorrow...Joe
Posts: 409 |
I had a few minutes to take a photo of mine. It measures 16" x 6". It also swings to the side and plugs into a socket above the door. for some larger photos Go Here
Posts: 3,163 |
The socket above the door is flat & the one on the roof header has a taper...Joe
Posts: 409 |
I'll take a photo of it shortly
Posts: 409 |
Here is what I have in my 33 master Coach. Not sure if it is 100% correct. This one is flat to the sides The one on the header is at an angle Plugged into the header From farther back ![[Linked Image from dale-lynn-james.smugmug.com]](http://dale-lynn-james.smugmug.com/photos/i-2MRsnxw/0/XL/i-2MRsnxw-XL.jpg)
Posts: 48 |
Dale and Joe thanks a bunch for the info and Pixs! Dale the pixs are perfect and Joe explains more of the different taper sockets...the pixs clearly show i have the right hardware...now only one more question...is there just the one visor for the driver or does the passenger get one also?? Mucho thanks again now i have a project for tomorrow in the shop.
Posts: 409 |
Mine only has one, some Masters have two. I was going to ad a passenger visor until I remover the header upholstery to fix the windshield wiper motor and found that the passenger side on mine was not prepped (drilled or machined) for a passenger visor so I abandoned the idea. Hear is a Master sport coupe with two visors ![[Linked Image from dale-lynn-james.smugmug.com]](http://dale-lynn-james.smugmug.com/photos/i-GTNjVdv/0/XL/i-GTNjVdv-XL.jpg)
After many years of searching I finally found the correct visor for the passenger side on my Eagle. Stress time in installing it. I hate to do things that only give you one shot at it. Everything came out perfect.
