#269810 02/06/13 07:26 PM
MrWzrd Offline OP
Finally got the last of the chassis and brakes finished up and before I put the engine/tranny on the chassis I want to replace the tires. Currently it has some 6.75 x 15 tube tires on it but I would like to change out to a similar size tubeless radial. Rather than figure it all out on my own I figured I would start by running the question up the vcca flagpole.
Is there a tire size that works well as a direct replacement for the originals?
48 Fleetmaster 2 Door Coupe
Completely disassembled and being rebuilt from ground up.
MrWzrd #269829 02/06/13 10:45 PM
P205-75 15 is the replacement size. They are slightly wider and lower than a 6.70 X 15. The 215 is closer to the corect diameter but kind of overly wide looking.
I would suggest not buying the tires until you are ready to do some serious drivng. Radial tires can loose their tread when they get a feew years old.
Chev Nut #269912 02/07/13 09:20 PM
MrWzrd Offline OP
Thanks, that's pretty much what I had guessed using a tape measure.
Don't have a choice in buying tires now...the ones on the car were put on in 1960.
it's getting real annoying to have to put air in them each time I want to move the chassis around, and with the additional weight of the drivetrain I doubt I will be able to just pick it up and move it.
MrWzrd #269952 02/08/13 10:42 AM
Seeing you are not driving it why not put slime in the tires rotate the tire to cote the in side. I have done this a number of times and it worked well. Slime is not intended for road use.
Al
a3alf #269957 02/08/13 11:55 AM
MrWzrd Offline OP
4 brand new 205/75R15 are now on. Thanks for the help.
I even took the time to sandblast, prime and paint the rims. (metal flake emerald green with silver pin striping)
Total time 8 hours. Total cost $48. ($40 for 4 used tires, $8 for valves)
