#269192 01/31/13 01:58 PM
james_h Offline OP
Can anyone tell me, or post a photo of the routing the main wire harness takes after it comes through the floor panel? Either this new harness (Filling Station) is too short or I missed a turn. Please keep in mind I did not take this car apart. Thank you...JIM
Here you go Jim,this was the cowl of my Sport Sedan before I took it apart to use it in my Coupe. The wires are still hooked up under the dash and the dimmer wires are by the floor. Just a little bit above is the mark of where it was under the plate and the double clip next to the speedometer cable is where it was routed. Hope this helps. By the way, the cheque is in, thanks.
james_h Offline OP
Thanks Pat...JIM
