Lou Offline OP
If you're tired of over revving your engine, the best resolution is a higher ratio Ring and Pinion gear. It improves mileage, increases engine life and makes for a quieter ride.
Larry Jackson, 805-441-2627, Is considering making ring & pinion gears with 3.36 ratio for 34 - 39 half ton trux. it also fits 34 - 36 Master Deluxe passenger cars. If you're interested, please call and let him know. He needs a run of 25 before he can start. If no one is interested, it won't happened.
If you have a 1930 - 32 Chevy, he has already made 3.50 gears for those, with many accolades from the purchasers.
Lou
Lou,
When your friend get to 40 Master Deluxe, let me know.
doc
It is not necessary to reproduce "high-speed" gears for a 1940.The 3.73 gears from a Master 85 or the 3.55 gears from a 1950-54 Power Glide can be installed.Installing a complete rear end from a Master 85 requires the least amount of work.
Chevgene,
Thanks. I have a line on a complete rear-end and torque tube from a Master 85, if my friend from our local club ever get around to "Rodding" the Master 85 he has. Of course, I will most likely have to install new brake linings, etc., - again - when he gets ready. Of course, I already have one of his rear brake drums on my car, Mine was grooved beyond repair.
Doc
Doc
Lou Offline OP
37 - 54 passenger cars have hypoid Ring & Pinion that are interchangeable except for torque tube length. . .
34 - 36 Master Deluxe passenger cars and 34 - 39 half ton commercial use spiral beval Ring & Pinion that are interchangible. These are the 3.36 gears that he intends to cut. . .
I've personally achieved this ratio by more expensive and less reliable means, and the first trip down the road makes it all worth while. . .
Happy touring, Lou
