#26878 08/30/04 08:21 PM
Can someone please tell me if the oil holes in the rocker shafts in a 39 engine are facing the top or the bottom of the shaft, under the rocker arms.
#26879 08/30/04 09:01 PM
They face down i just did my 37 also the shoulder bolt will only let you put it in one way if you look were the holes for the bolts are you'll notice they are bigger on one side then the other
#26880 08/30/04 09:04 PM
Oil holes face down on the rocker arm shafts. Believe the bolts that hold the shafts down have a shoulder so that they can only go one direction.
Walt D
1934 Mstr 4 dr/sidemnts
1937 1/2 ton P/U
1953 Bel Air HT
1946 Aeronca 7-AC Champ
#26881 08/31/04 10:48 AM
Thanks for the information.
