Posts: 6 |
I have a 26 Chevy that I am trying to remove a wooden spoke wheel rim/tire off of car. I have removed the cotter pin and nut. What is the next step to get the rim off?
Posts: 375 |
Gidday Fellas,
Well we've had 15 views to your question and no one can be bothered to suggest something, even if it is a simple response anything would be nice to receive...
So lets see, I would say just pull the bloody wheel off, its not rocket science with these old cars.. I gather the wheel is jacked off the ground? and no doubt it will be hard to remove as you say, so next step... a wheel puller is needed, best investment you will make with little or no damage in the removal process to threads etc.
I know this was probably be not much help to you but its better than nothing being posted.
Best of luck
Hi, I see you are new to the Forum. I would like to welcome you and hope you will make use of the wealth of information available here. Assuming the vehicle is still drivable, replace the washer and nut. Tighten it loosely, then back off a full turn. Now find a parking lot or a safe place and drive the car in tight circles at a safe, but fast pace. You should tell by driving when it comes loose. If the above plan doesn't work, then a puller designed for the job will be required.
Posts: 6 |
It is up on jacks, new to this, would a universal puller work?
Posts: 6 |
Can't drive it yet, so I guess I will need a puller, the rear wheels won't budge!
Lead hammer, heat and a puller may all be required. If you want more detailed discussion send me a PM (personal message). I live ~ 60 miles South of Stafford.
Posts: 1,623 |
Or - put the nut back on a ways to protect the threads, and whack it a few good blows with a hammer. Then see if you can wiggle it loose. If it will move on the shaft after that, sometimes some patient wiggling will get it off.
Chevy Guru
Posts: 375 |
Gidday Fellas,
Well there ya go, no worries at all Jbw2691, thanks right back at ya and I'm glad I could be of some assistance.
New and Unappreciative.
Posts: 140 |
Or - put the nut back on a ways to protect the threads, and whack it a few good blows with a hammer. Then see if you can wiggle it loose. If it will move on the shaft after that, sometimes some patient wiggling will get it off. If you're going to give it a go this way, jack the opposite side wheel off the ground. Regards Al
