#267857 01/18/13 01:50 PM
james_h Offline OP
Does any have or have a source for the special "cupped" washers that locate the trunk hardware? I will need 16 of them. Thank You.....JIM
Check McMaster-Carr or other nut and bolt people. They are called wave washers or spring washers. You can also google it to see if you can find other sources.
james_h Offline OP
Thanks Chipper, I will try.....JIM
