Darryl ,I water sanded and HAND polished my 35 std coupe back in 1980 in ditzler double deep black nitro.. I will do the same with my 35 standard roadster, as i already have 4 gallons of nitro and all the primer and thinners.
My friend Brian sprayed at his body shop, all the primer and i blocked it out under his supervision. He sprayed it black nitro and I water sanded it between coats with 600 water paper a total of 3 times. I hand polished it over 3months of work using medium grit compound and fine grit and then switched to turtle wax scratch polishing compound. Brian introduced me to a new wool pad , electric buffer and a box of dry durham corn starch to super fine remove scratches and swirls. I heard brass polish also works but never tried that , the corn starch is finer.
Unfortunatly my friend and all those at the shop are gone for 20 years.
Two years ago i was replacing my front fenders and figured I could prime , prep and paint them myself , which i did and am extremely happy with the final result.
It was much easier this time doing the polishing and finishing using 1000 grit water paper followed by 1200 , then 1500 and finally 2000 grit.
The polishing secret this time is too use the MEGUIARS POLISHER that is a random orbit and is 6 speeds and 3 different foam polishing pads. I used all 6 of the meguiars polishing compounds and you can count your nose hairs in the reflection. Their system is so easy to use and unless your in dreamland somewhere while doing it , your not going to burn thru like you would with a wooly pad.
mike lynch
