Posts: 63 |
What is the proper color for rear tire bracket. Was it the same color as the body color or was it black.
Rich33 1933 5 Window Chevy Master Coupe 1951 1500 Chevy Truck 5 Window 1968 Chevy Camaro
For better coverage you might want to post your question in the 1933-1936 forum. Good luck!
The bracket is painted black.
Posts: 63 |
Whats my problem with bracket I have. Bracket fits frame but the lug nuts do not fit wheel. I think it's for a different year. Was there a different wheel used for spare. I purchased car disassembled. The 3 lugs are smaller then the 6 lug holes. What am I not seeing here.
Posts: 956 |
Master would have a different pattern than a Standard.
Roger
Posts: 3,292 |
PERFECT GUY TO ANSWER THIS QUESTION IS JOE IACINNO, as joe knows a lot about 33 standards and 33 masters..
mike lynch
Posts: 1,774 Likes: 4
Posts: 1,774 Likes: 4 |
The Master spare and the other wheels would be the same size but as said above, the Masters had different wheels than the standard. My guess would be that you have a standard spare tire bracket.
Ed
Posts: 1,884 Likes: 12
Posts: 1,884 Likes: 12 |
33 Standards and 33 Masters had the same size Spares as the Tires themselves however the Masters are 6 Lug and the Standards are 5 Lug thus they will not interchange. If you have a 33 Master then you need a Spare Tire Bracket for a Six Lug.
Jon T.
Posts: 63 |
Thanks for your help. Big help. I was able to find correct bracket on line. Bolt pattern looks correct.
