Posts: 258 |
Does anyone have a photo of the correct mounting position for the front hood (on radiator shell) latch mounts? Thank you...JIM
Posts: 17 |
I have been notified by Jim that he has found his information and request that this task be deleted, I'll attempt to just close it instead.
Jim 1933 - 1936 moderator
Posts: 258 |
Posts: 3,292 |
I am pretty sure they really only fit and the bracket also into specific holes.
mike
Posts: 258 |
Hi Mike: The problem is that they can be installed on either side. In this case, I removed the bubble wrap from the hood and placed it on the car. JIM
Posts: 3,292 |
Jim when you look at the closing mechanism HOOK and the bracket, the flat part faces outward and the angled pointy part faces inward to accept the hook.
The one that goes low on the cowl section the bent area faces outward.
mike lynch
Posts: 5,906 Likes: 8
Posts: 5,906 Likes: 8 |
Discussion closed at originator's request.
Bill Barker Previous VCCA CHAT Administrator (VCCA Member: 9802)
