I have a question concerning the side window channel that is installed between the glass frame and the windshield (front) and the glass frame and Top assembly (back). In addition to using Channel - Side Window, preflocked rubber 9/16" wide (FillingStation part no AF-437A, I understand that I must also use the "Cabriolet side window channel retainer 12" long, use with 70-1169" for both the front and the back? Are these pieces attached with FillingStation Part CR-175 "Passenger Tube Nut? Are these pieces also joined by adhesive?
Is there any Channel Moulding at the point where the Window joins the top? Is this a part of the Top Manufacture, or is this something I need to purchase? If so, what is it called and how is it attached?
Is there any Moulding to stop wind noise between the windshield and top? If so, what is it called and how is it attached?
Are the floor boards supposed to be unpainted?
Would judges take off points if a clear sealer was applied to both board faces?
Is the outside of the toolbox (below front seat) painted. If so, what color should it be to be OEM? Seat is a dark leather that LeBaron-Bonney said was OEM for Trim 8.
Thank you
Perry A. Seaton
