Posts: 188 |
does anyone have the tie rod end specs for 38. I need the size of stud and taper. trying to use later tie rod ends. thanks
Posts: 2,323 Likes: 6
Posts: 2,323 Likes: 6 |
I may be wrong but I don't think there is a taper involved. There is a trick though to removing the ball studs.
Posts: 188 |
OK, is there a taper or not in the left and right tierod arms on a 38?
All the posts that I have seen talked about a straight bore. My 1951 drag link did not have tapered holes. What they did have was a slightly enlarged very shallow area on the back end of the hole. When the ball stud was swaged in, the metal filled in the area and without removing the metal, it wouldn't budge under a 20 ton press.
Posts: 350 |
Are you planning on using the original gear box, drag link and tie rod? Years ago I upgraged a 37, wouldn't do it today, with 60's saganaw box and cross tie rod by replacing the bracket on the backing plate with a a 50's part and using a tapered drill bit for newer style ends. Worked well but am more keep it original today. The originals work well if you set them up correctly and grease them well.
Randy
Posts: 12 |
