#264342 12/16/12 01:40 AM
Hi Guys,
Would anyone have a picture they could post of wind wings on a 28 Tourer, and how they attach to the windscreen upright.
Cheers
Ray
Hi.
On my 1927 Touring it looks as picture
http://www.ollesrv6.se/ren91.jpg
Olle
I have a set of wind wing fittings on my 28 roadster from vintage & classic reproductions here in aus. They aint cheap but you dont have to drill any holes, they clamp around the windscreen post. Look great stop a lot of wind. Hope this helps.
Neil
[Linked Image from img12.imageshack.us]
Arvid
Thanks Neil, Olle and Arvid.
The pictures are excellent, and its a lot clearer now.
Cheers
Ray
Gidday Fellas,
A couple of weeks back I decided to make up a pair of "windwings" for my Chev.
I priced the correct chrome mounting brackets which were not to bad in cost I thought but the idea of having new shiny chrome brackets hanging off old Monty just didn't sit well with me and I wanted something also that I could remove quickly if needed.
I'm more your practical Chev fancier and not your showy type as you have probably gathered by now so I grabbed out some metal strap, sprayed them flat black, had our local glass man cut out the 5mm clear perspex (500mm x 150mm) and I found some domed head bolts.
After a bit a measuring and bending of the brackets to line up with the 2 x windscreen bolts I came up with these
[Linked Image from i710.photobucket.com]
Then after a test drive I came back happy with the result and rounded the corners with the flapper disk on the angle grinder to what I was happy with.
Now I know they are not the correct size, or may look a little odd in appearance to the purists but I just wanted something that worked and worked very well and a trip and these do just that, I am very impressed with lowering of the wind noise and no more wind in the ears, the baseball cap now stays on the head and the wind burn on the face is also less.
Anyway each to their own....
Cheers Grant.
"We're not painting it all fancy"
http://montythe1928chevrolet.blogspot.com.au/
Great result Grant,
A practical solution, fits the car and suits the owners requirements. That's the main objectives.
But the hair, what about the hair, does it stay in place?
Cheers
Ray
Originally Posted by 1928isgreat
Great result Grant,
Ray
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Axle grease on the hair, go for the 50's rock N roll greaser look complete with black leather jacket. With that grease hair will not move.....you actually still hair hair....GOSH !!!!!!!
mike.... Agrin
What about the hair? What hair? How about the hearing aids?.... does the wind set them off?
Well, what I say is Whatever flops your mop! is good enough for me too! They Look good on Monty.
