Posts: 4,446 |
Steele rubber is very accurate about rubber parts. I think a complete rubber kit for a 38 chevy was something like $2100. Very expensive. I guess if you shop for the best it costs a alot.
Posts: 1,135 |
Steele rubber is very accurate about rubber parts. I think a complete rubber kit for a 38 chevy was something like $2100. Very expensive. I guess if you shop for the best it costs a alot. I don't think a pack of rubbers should cost that much......ED
Posts: 4,446 |
I have a friend that has a 35 Packard he's been working on restoring for 18 years !!! He said he paid almost $4k for the steele rubber complte set. He's 70 now. I doubt he ever gets it rolling.
Posts: 2,323 Likes: 6
Posts: 2,323 Likes: 6 |
Well I think that is a really nice looking Master. However I know of one part that is not original. The rocker panel on the driver's side has been replaced with one of the poorer reproductions that does not follow the curve of the door. You can see that it has been cut, bent out to create a curve and there is a triangular hole as a result. I am about to install a new rocker on the driver's side and my rocker is made by EMS and it has the correct curve.
I want to correct my comments on the car in the video. I guess what I was looking at is the stripping that goes between the rocker and the running boars to stop mud from splashing through. Is that strip supposed to be the same color as the body?
Posts: 406 |
Since this thread is about 1938 running boards, were they originally all painted black at factory or body color?
body color on top. Black underneath.
Posts: 406 |
Thanks Gene. I've seen both all black and body color on top and wasn't sure which way they left the factory.
That is really interesting. I guess that probably got painted in place along with the body.
Posts: 724 |
Assuming Old216's comment is correct about painting the runningboards after they were installed, does that mean the runningboards were painted in laquer and not enamel? thx. Billu38
The body proper was painted at the Fisher Body plant. The "sheet metal" (hood, fenders, running boards) was painted at the Chevrolet plant. These parts were painted before they were assembled to the car body. From what I can see the running boards on my '39 are lacquer. Wheels were enamel.
Posts: 724 |
Thanks Gene..were the wheels the only item painted in enamel? Were items like the engine sidepans also laquer? thx. Billu38
