#264282 12/15/12 03:26 PM
Lemont Offline OP
When I purchased my 32, I also received a inside heater. At the radiator there was a T style connection which was in the hose. of course the rubber radiator hose is shot Any Idea where I could get a new T connection?
Paul Orednick
I have got a metal fitting that can be installed in a radiator hose and use a5/8 heater hose. Check with a NAPA or local parts store, I believe Four Seasons was the brand.
I have a metal elbow with a t fitting welded in which goes on the lower radiator hose.
karl
The T fitting should be able to be removed and re installed.
Al
