#263503 12/08/12 03:20 PM
hey guys-
can someone tell me how the window handles come off a 31 2 door coach? I need to remove all 4. my 51 has set screws but these dont seem to.
thanks
joe
one more Question-
anyone have a god site to decode VIN numbers? all the sites i tried wont decode what i have.
the vin i have is 2AE95710. the tage is on the reg and i found the plate in one of the boxes. the tag on the fire wall has some numbers ie job number and 2 others what do these mean.
thanks agian
Joe
The window handles are held in place with a "U" clip and it takes a special tool to remove the clips. You can also remove the clips with a small ice pick or a small flat blade screwdrier.
Skip you beat me to it I removed my post
2AE95710 is not a VIN number, it is a car serial number. VIN numbers were not used until the 1960's.
"2" indicates that your car was made in the Tarrytown, New York factory.
"AE" is the series, which is 1931 Independence.
"95710" means that your car was the 94,710th car made in the Tarrytown factory in 1931. Note: All car serial numbers started at 1,001.
Post all of the numbers that are on your Fisher Body cowl tag and we will tell you what those mean as well.
Andys29 #263508 12/08/12 03:39 PM
Ya, it looks like we were both typing at the same time.
Thanks guys -
i will post the body numbers later tonight or tommorow.
Joe
Filling station has a great cheep tool that you will use to install the U clip when ready...Buy a few of the clips also.
Paul Orednick
Lemont #263649 12/09/12 08:01 PM
I do not think you need an "install tool". You just put the spring clip on the handle and press handle onto shaft and clip springs into place. Tool is only helpful for removal.
Gunsmoke #263659 12/09/12 08:52 PM
iagree
A little bit of White Lub on the tip of the post helps the clip expand to snap on.
It's Wise to choose a six!
