#263343 12/06/12 10:18 PM
stuscar Offline OP
What does the bracket(s) look like that that the glove box door pivots on? My door has the L shaped hinge pins attached but I'm not sure what pieces allow it to swing open from the dash.
Stu Allen
I was just looking at a 34 master dash yesterday, and looked at those parts. Actually they are quite simple, a couple of short pieces of flat metal that form over a ? type shape at the end that fits over the L shaped pieces. You will have to make them. They have small 10/32 or 3/16 ? size nuts and bolts snugging it down.
I would use buttom head allen heads because they would present a screw type head that would be difficult to see. Or use machine screws with blade or phillips heads.
mike lynch
stuscar Offline OP
Thanks, Mike, Now I know what to look for in my misc. parts stash.
Stu Allen
Stu Allen
email me at
mike350 at rogers dot com
and i can take and send you a digital picture.
mike lynch parking
Hi Mike: I ran into that problem with my 34 Master; I made a pair of brackets from 3/16" cable clamps (like OEM fuel line to frame clamps). It takes some finesse and time but mine works fine and the glove box door is dead center in the cavity. JIM
Not sure if the clamps are stock or home made, I just happened to have had the 34 master dash out of its box , as I was comparing it to my 34-35 std roadster dash and also my 34-35 standard fisher body coupe dash.
The roadster dash is actually 2 " wider than the fisher body closed cars.
The 34 master dash will fit in a 34-35 standard fisher body perfectly, its not wider , but it is deeper up and down measurements .
mike lynch parking
Thats an excellent idea, i have some of those in 3/16 also
mike
