#262584 11/30/12 10:52 AM
goffe Offline OP
For the '32 the two cork floats were placed end to end on the wire. The modern fix is to go to a neoprene, alcohol resistant float. Should I use one or two as in the original cork?
goffe #262629 11/30/12 05:53 PM
The floats I got from Snyders Antiques were the length of two cork floats. In the '30, one plastic float replaced two cork floats on each arm.
ArtM
