Posts: 4,446 |
Try it again I changed it a little bit.
Posts: 714 |
There it is...Nice car Iwonder why the small air filter?
Ken's 1940 Special Deluxe Sedan 1970 Cadillac Hearse
Posts: 4,446 |
Don't know,but really slick car. I like it.
Posts: 1,019 Likes: 3
Posts: 1,019 Likes: 3 |
Really nice car. I noticed the molded heater hose, adds another clean set lines to the engine bay.
Posts: 4,446 |
The molded hoses are a nice feature. It cleans up the engine bay.
Posts: 415 |
She sure is a beauty! But what is that square, louvered thing, above and behind the valve cover? any Ideas? ______________________ Joe's 37
Posts: 121 |
My car has that same louvered box behind the valve cover, I have never been able to figure out why it's there.
I must admit that I can't see the device you are talking about, however, from the description it is the vent behind the radio box. I note from the pictures that the car is equipped with the radio.
Posts: 6,689 Likes: 21
Posts: 6,689 Likes: 21 |
Ray, I can't see it either. All I see is the indention in the firewall. It is a nice looking car. Charlie  Note: No humor or non-technical comment intended even though the comment that it was a nice looking car, seemed justified. Sorry.
Posts: 7,046 Likes: 107
Posts: 7,046 Likes: 107 |
I must admit that I can't see the device you are talking about, Ray, look at picture #5, it's on the cowl showing between the upper heater hose and the back of the accessory horn.
Yep, now I see it. I was correct that it is a part of the radio.
Posts: 4,446 |
Click on the link again then go to the right of the photo and you can make that photo much larger
Posts: 152 |
I recall the 37 has two round knock out plugs in the center firewall where radio amp heat escapes thru a louvre cover. On my 39 the two round plugs are next to the regulator so the radio box mounts above the pedals. Mike
Posts: 4,446 |
Wonder why a 38 doesn't have the same thing, I thought the radios were almost alike.
Posts: 56 |
The '38 has the exact same thing. There are two knock out plugs with little tabs to grab and break the plugs off the firewall leaving holes. The louvered thing is called a muffler for some reason and has two tabs at the top for self tapping screws that go into little holes already in the firewall and a tab at the middle bottom that fits over the stud holding the speaker to the firewall and a nut holds it there. It then covers the holes in the firewall. It is only used on the Super Heterodyne 7 tube radio with the firewall speaker. Literature talks about equalizing the pressure behind the speaker that's up tight against the firewall pad on the cabin side. They were probably worried about something they didn't need to be worried about.
RD/B
Posts: 4,446 |
AMAZING...I'm on this forum almost everyday. I can't believe after 3 years I'm still reading things about my old coupe that I never knew. Great post.I think you're the only one on here that's ever said anything about that subject. I'm impressed. Thanks
Posts: 56 |
I just looked back at the photos. The installation lit also calls for a ground strap running from the speaker stud to the back acorn nut holding the valve cover .
RD/B
Posts: 4,446 |
At the bottom of the radio muffler I see a Vacuum plug over a stud. I guess that's the connection where the ground hooks up? I guess this car doesn't have that ground wire.
Posts: 56 |
Yeah, I think there is some red pretty thing over the end of the stud and definitely there is no ground strap. And I agree that is where the strap would hook up. The stud is hooked into the back of the speaker and held to the firewall with a nut; the muffler then goes on the stud with its own nut and that nut is the one that also holds the ground strap end.
RD/B
Posts: 714 |
I like the horn relay mounted on the trumpet horn. It keeps the firewall from being cluttered up. Is this where the factory mounted them?
Posts: 4,446 |
Yes and the wiring size is pretty large.
One thing he's missing is the support strap for the accessory horns. Not a good picture of it but you can see it.
Posts: 4,446 |
![[Linked Image from i1302.photobucket.com]](http://i1302.photobucket.com/albums/ag124/wawuzit/horn.jpg) Camera is up and running!! I had to make a support for my NON ORGINAL horns..smiles
Hi Steve, I may have asked you this before....... If you ever come across the bracket that spans the radiator support rods for the town and country horns let me know please.
