Rich33 Offline OP
Where does the batery ground attach to. I have heard of different locations. I also need to know where the ground wire attaches to on the motor to frame. Possible attach pictures. Thanks
Rich33
1933 5 Window Chevy Master Coupe
1951 1500 Chevy Truck 5 Window
1968 Chevy Camaro
I put mine on one of the bolts to the transmission. A page in Service News shows the ground to the freewheeling cover.
Hi there and welcome to Chevy Chatter. Glad to have you with us.
For 1932 the engine ground strap went from the driver's side bell housing bolt to the frame cross member. There is a hole in the cross member for the ground strap bolt.
Is it the same setup for the 34 Master?
Einar
The 34 Master uses a braided ground strap that goes from the negative battery post to the top passenger side bolt on the transmision tail shaft. I am using smaller braided ground straps for engine to frame and body. All these straps are available at NAPA. Hope this helps. JIM
