Posts: 112 |
I am at a stand still because I can't find up to date color codes for Horizon Blue and Indian Ivory. The numbers that I have been able to get off the internet are not helpful to the auto paint suppliers that I have tried so far. If anyone has a number right off the can I would appreciate hearing from them. Thanks
Posts: 1,072 |
will get back to you tomorrow will look in my ppg cross reference book and see what comes up numbers wise if you had your numbers off the tag on the cowl it would help a lot andy
Posts: 112 |
Thanks Andy, the info from the plate is Paint No. 556 Do you know what the trim number tells us? Mine is 324. Fred
Posts: 1,072 |
the numbers that asked for are completely different than the numbers on the plate,are you changing colors or is this the color of the car at the moment will look up the numbers from the plate tomorrow to see what they are any way here is what you asked for 1954 chevy horizon blue GM #543 PPG #10946 INDIA IVORY GM #547 PPG #80613 obolete new number PPG #8818 C CHAMPAGNE WHITE 1955 INDIA IVORY GM #593 PPG #8026 1956 INDIA ivory gm #694 ppg #8026 1957 india ivory GM #ONLY PPG #8026 ALL YOU HAVE TO DO IS GO TO YOUR PPG PAINT GUY AND HAVE HIM LOOK UP THE PPG NUMBER AND HE CAN COME UP WITH THE FORMULA FOR THE PAINT YOU ARE LOOKING FOR HOPE THIS HELPS ANDY
Posts: 1,072 |
the c after 8818 means nothing should have bee stat of champagne will look up the other number you gave me today
Posts: 1,072 |
LOOKED UP YOUR NUMBER #556 IT COMES UP IN MY TWO-SECTION AS FOLLOWS TWO TONES U 80613 INDIA IVORY AS WE KNOW NOW HAS CHANGED TO THE NUMBERS I GAVE YOU BEFORE AND L 10946 HORIZON BLUE I DONT KNOW WHAT THE U&L STAND FOR MAYBE GENE CAN HELP ON THAT ONE THE TRIM NUMBER 324 IS WHAT THE CAR IS EQIUPPED WITH AS IT COMES DOWN THE LINE IF I CAN REMEMBER CORRECTLY HOPE ANY OR ALL MY SEARCHES HAVE HELPED CHEVY'S ARE THE BEST ANDY
Posts: 112 |
Thanks Andy for all you help and information. With great anticipation and excitment I went to the local Napa paint dept. only to find out to start with I cannot buy single stage in my state of Delaware but you can buy the reducers which makes no sense. The next thing the fellow looks at are the numbers and works at his computer and comes up with no cross reference. I'm right back to where I started from. I can get base coat clear coat as soon as I get a paint number for it. I have no experience using base coat clear coat. Boy life use to be so simple.
Posts: 1,072 |
GO TO A REPUTABLE PAINT STORE THAT SPECIALIZES IN PPG ,DUPONT OLD DITZLER THOSE ARE THE NUMBERS I SENT YOU MY PAINT GUY SAID THE PAINT CODES FOR THE NUMBERS I GAVE ARE STILL AVAILABLE THATS ALL I CAN DO GOOD LUCK
Posts: 3,292 |
Thanks Andy for all you help and information. With great anticipation and excitment I went to the local Napa paint dept. only to find out to start with I cannot buy single stage in my state of Delaware but you can buy the reducers which makes no sense. The next thing the fellow looks at are the numbers and works at his computer and comes up with no cross reference. I'm right back to where I started from. I can get base coat clear coat as soon as I get a paint number for it. I have no experience using base coat clear coat. Boy life use to be so simple. xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx You can still buy nitrocellulose lacquer or acrylic lacquer.........paints and thinners. HIBERNIA AUTO RESTORATION in NJ.......google them for phone number. They have web site with prices of paint and make all original colours. life does get simple again, if you know how to paint, nothing easier than nitro or acrylic and stuff will not kill you if wearing wrong mask !! mike lynch
