#261073 11/15/12 12:13 PM
dunfire Offline OP
I at one time knew how to take the latch off the back of the 1936 Truck glove box lock, but memory needs to be defraged. As you rotated the key you pushed on the square end to release it?
1936 GMC T-14 low cab. TA for 1935-37 GMC, Director of the Gulf Coast Region
dunfire #261147 11/16/12 12:32 AM
Pull the square outward from the back of the lock, jiggle the key and the key comes out as does the latch and latch.
To reassenble, push the latch in until it clicks, look into the lock cavity and push the latch just enough to see the indention in it, push the cylinder in (with the key in it) and the peg on the back of the cylinder lined up with the indention on the latch, turn the key and it will click into place.
Believe it or not, this is the second time today I have told someone how this is done.
Good luck!
Tech Advisor for 1937-38 Chevrolet Trucks
dunfire Offline OP
