Davis38 Offline OP
Hey All,
So I managed to snap the stud off my rear ventilator window, while trying to put the handle on. Anyone have any sort of way to fix this without having to buy a whole new window piece?
Thanks,
-Davis38
did you break the handle on the splined shaft of a vent regulator or does the handle fit over a stud pressed into the window frame?
If it's like the Canadian cars (no regulators), the lock handle fit over a stud pressed into the window frame.
Davis38 Offline OP
I broke the stud that is pressed into the frame.
could you drill and tap the hole for a new threaded stud? I guess you would have to mod a bolt to accept the handle?
