Rating: 4
#260801 11/12/12 05:17 PM
i have replaced everything,master cylinder,brake lines,shoes,hardware.everything works except when im coming to a stop my front end shakes.cant seem to figure out why.also get a clunk sound when i hit the brakes.
chebby48 #260803 11/12/12 05:35 PM
I don't think it's your brakes...Have you checked the tie-rod ends, steering stabilizer bushings and the like...? Kevin
Forgot to ask of any problems before you started on this brake up-grade adventure... laugh
Last edited by kevin47; 11/12/12 05:39 PM. Reason: Can work also BE an adventure...?
chebby48 #260808 11/12/12 05:47 PM
Chebby48,
In addition to what Kevin has suggested:
Check tow-in for the cause of the shimmy, also.
Check the travel (arc) of the brake pedal arms for the clunk. You're probably hitting the floor pan at the upper edge of the opening for the pedal arm.
Good luck with it,
kevin47 #260823 11/12/12 07:36 PM
i bought the car undriveable with no breaks.maybe i need to rebuild the front end.
Originally Posted by 41specialdeluxe
Chebby48,
Good luck with it,
ok.could it be the wheel bearing also
chebby48 #260826 11/12/12 07:42 PM
Also check steering gear to frame bolts.
41carguy #260832 11/12/12 08:06 PM
wow i just remembered it was missing a bolt.im gonna check and put one in,geez great info guys,thanks
chebby48 #260840 11/12/12 09:48 PM
Hows your pitman arm (rubber) bushing's...If your car's all over the road it's a good place to start...Get that steering box bolt in there first...
chebby48 #260843 11/12/12 09:52 PM
Chebby48,
Lift up the car...See if you can "wiggle" the wheel by simply rocking the tire...
