#259711 11/02/12 09:19 AM
gerejon Offline OP
I have two different size ring gear rivets and need help identify them.
Overall length of the rivet is 1 5/8" and the other is 1 3/4"
I want them for the 34 Chevy Standard
Any information and help would be appreciated.
if i were you i would bolt it in . it is really hard to expand the rivet so that it is tight . i have used heat a 50 ton press a air hammer a special jig . just put a drop of loctight the red stuff .hope this helps
I agree -- you'll never get the rivets tight enough to hold.
The gear is held by friction between the gear and the carrier (?), as it is not simply shear strength of the rivets that you have to be concerned with.
When I put new gears in my '35 Standard, my automotive engineer cousin convinced me to get the (1/4"?) holes in the gear bored out, and use larger bolts than would fit in the rivet holes.
A high-quality bit on a milling machine (with lots of cutting fluid!) got the job done on the gear, then I put in about 3/8" grade 8 bolts, tightened to just under the point of failure.
As I recall the mating holes in the carrier were already larger.
Hope this helps.
1930 Coupe 1935 Coupe 1953 210 1954 1-ton automatic 1959 GMC half-ton
gerejon Offline OP
Thanks for the information about using bolts but I really want to know which size rivet was used back then. I have no intentions of changing my ring gear just want to know which one of the two sizes would have been used. Thanks
