Posts: 168 |
have checked all the sites that i can find and still can't id this engine. number on the pad is-caa167912. info on the rear of block d26a--397001. the engine came from a 3-4 ton truck-68 chevy. any help? thanks
Posts: 1,125 |
Is it possible there is one more digit on the casting number? My copy of Chevy Small Block casting number guide shows 3970014 as a 1968 or 69 350 for car and truck. Sid
Posts: 168 |
yep, your are right. the number is3970010. thanks for your help
Posts: 168 |
hey 6wheel, is this a four bolt? thanks, jerry
Posts: 1,125 |
Jerry, the book does not say whether it is 2 bolt or 4 bolt. Re-check your number, it should be 3970014. Sid
Posts: 168 |
thanks again 6 wheel. rechecked the number and its 3970010. don't know what to think of this. any ideas? jerry
Posts: 2,576 Likes: 2
Posts: 2,576 Likes: 2 |
check the d26a casting date again. i suspect it should read d269 which would code as a april 26 1969 cast block. are you sure of the stamp pad data you supplied?mike
Posts: 1,125 |
Looking further in the book, I found 3970010, and it shows... 350 200,255,270,300,330,370 car, truck and corvette for 1969-1979. Could it be that the 350 is cubic inches, and all the other numbers are horsepower? This book gives only very cryptic info. Sid
Posts: 168 |
i'll try and recheck the casting number again tomorrow. thanks to all that have tried to help me solve this problem, jerry
