#25918 12/30/03 12:27 AM
Whats the trick to replaceing the ruber shock bushings.How do you get the new ones in?Thanks in advance,Ron.
1942 1/2 Ton. 1951 1/2 Ton. 59 cushman scooter.1960 biscayne Sedan. 1966 c/30 motorhome http://community.webshots.com/user/ratmann1
I assume you have rubber bushings that are pliable. If they are hard, forget it!. if soft, push out the inner brass bushing, then you can push the rubber into the eye of shock or whatever. Then push the brass bushing back into the rubber. I made a sort of pilot to help the thin bushing go into the rubber without cutting it. Sort of looked like a small caliber bullet fitting into its casing.
HTH
Dennis
