DanK Offline OP
im cleaning the fuel lines and tank should i coat and seal the inside of it? or just clean it? not sure what to do
You will get many different opinions on the gas tank sealer since there are those that like the stuff and there are those that won't use it. However, as far as I'm concerned, if the gas tank is to the point that it needs to be sealed on the inside due to rust issues and etc., then the tank needs to be replaced instead. If the gas tank cleans up nice on the inside then leave it alone.
I am one of a different thought. Once the tank is completely clean on the inside, coat by instructions, with one of the currently available tank coatings. Either the blue or red.
It is very important to coat the tank as the area of the tank not covered by the fuel when parked exposes a large area of the tank that is susceptible to rust from the moisture formed in the tank. At one time I performed routine maintenance on a group of cars and trucks for the owner. I cleaned the tank on a 1946 truck and re-installed it. Within a year rust holes appeared on the top and sides of the tank not covered by the fuel. Every other tank I cleaned, I coated, and to this day there are no issues in those vehicles.
You are invited to scroll down to the TECH TALK in this Forum and scan the "School is in Session" (new). I am confident you will pick up several hints on maintenance and rebuilding.
Agrin devil
Hi DanK,
I am of the school of thought that believes in coating the inside of the petrol tank, and even did the vac tank also. No problems since 2009.
The word of warning is you must follow the 3 stage process to the leter of the law.
Clean
Derust and Etch
Coat.
The different suppliers have a variation but the basic process.
is the same.
We dont have ethanol in all fuels yet over here in OZ, but I have heard some say this may be a problem.
Good luck, and let us know how you get on.
Cheers
Ray
I have used the 10% fuel for several years now and absolutely no problems. I also coat all surfaces inside the vacuum tank.
Agrin devil
I coated the gas tank of my '30 almost 20 years ago and never had a problem. After boiling out the tank the inside of the tank become porous and tends to rust.
But be sure to follow the instructions carefully.
karl
Professionally boiled out the gas tank on my all original '32 back in 1973 after it had sat in a barn for 20 years with gas in the tank. The tank was badly varnished. The tank came out perfectly clean. Never coated the tank and it is still pristine inside of the tank 40 years later.
The saddle tanks on my '68 GMC were factory coated on the inside and the sealer lasted a year before the sealer dissolved and totally plugged up the fuel system. It was a real nightmare!
I have several friends that used the tank sealer recently and the gasoline ate the sealer.
Like I said above, some guys like the sealer and some guys don't like the sealer. Some have had great luck with the sealer and others haven't. I guess it is a matter of preference. I'm one of the dudes that prefers not to use the stuff.
DanK Offline OP
Im just not sure if its ok to coat because its the original tank, and im kind of nervous because it has strips on the outside of the tank that look like patches. so i have to make sure its not cracked and dont leak
Actually, you can stop small leaks and prevent any more by the use of the tank liner. The tank lining will also prevent damage caused by the tank "sweating".
The place where I purchase my tanks will not sell a new tank until it is lined.
Agrin devil
