#258252 10/18/12 11:01 PM
ron1967 Offline OP
does anyone make a rebuild kit for the vain type oil pump?
wasn't this used until 1928??
I can't afford to spend $300 bucks for the new gear type if the old ones worked for 13 model years, should be able to get another 1000 miles with new wipers, gasket and a spring.
thanks ron
Go to Tech Talk and scroll down to "School is in Session". Check the index for the location of modifying a later gear pump for your 1927 engine. You may find some other interesting things there also.
devil Agrin
