#258099 10/16/12 08:04 PM
how in the !@#$R% do you take the hub caps off without doing damage???
Do you mean damage to the caps or the wheels? I use a large flat blade screwdriver to pry the cap loose after putting a couple of layers of duck tape on the wheel to keep from scratching it. I don't think you should have any problems hurting the caps themselves.
1934 Three Window Coupe
[img]http://www.youngsdecks.com/YoungsDecks/1934_Chevy.html[/img]
Thanks! They are tight. Your car is the same colors as mine. I have a 35 - 3 window
