I discovered this weekend that the passenger side nut was missing off the bottom of the shock mount, the metal bracket that the lower portion of the shock bolts to, that then bolts to the suspension. The bolt to the suspension arm was missing. I had a washer and nut to be able to reattached the unit and it looks like the driver's side now but when I looked at the shop manual it looks like there is a rubber bushing between this piece and the nut. Am I missing some rubber bushings? It looks like this is supposed to float whereas mine is bolted in place.
