Posts: 40 |
Hello, can anyone furnish a photo of the in-dash starter button for a Master which uses a solenoid? If anyone has an extra, I will need one. Thanks, Jay
All 1935 Master Deluxe cars had a Starterator. That is the starter was actuated by pressing down the accelerator pedal. When the staterator gave problems you could purchase a kit to install a dash starter button rather then repair the starterator. It is listed in the parts book as conversion kit, part #1912939, push button type.
Posts: 980 |
Hi Jay, If you want it I have a p/b switch that requires a 13/16 hole but since you already filled the hole in the dash, I suspect you would rather try to find the correct starterator parts, sorry I don't have any.
If you have old Chevrolets, other old Chevrolets will find out where you live.
