#257168 10/06/12 06:45 PM
wawuzit Offline OP
My breather neck has been treated a little rough over the last 75 years. No matter how tight I try to tighten the hose type clamp (orginal) it still wobbles on the carb neck. A friend told me to get a T-bolt hose clamp the same size. It has 4 times the clamping power. I think it's really for Marine/aircraft applications. Has anyone ever used this clamp?
http://www.jegs.com/i/JEGS-Performance-Products/555/82001/10002/-1?parentProductId=744065
I don't want to crush the potmetal carb neck.... blush
Steve...Put a wide rubber band around around the top of the carb air horn... that will allow the air cleaner to vibrate with the engine shaking and still wont work itself loose/off.
You don't want to tighten a clamp around the air horn too tight,warp it, and make your choke stick....Good Luck>>>ED
wawuzit Offline OP
Thanks. I guess putting that much pressure on the car neck might not work. Maybe I can find one on Ebay. orangeupset
