Posts: 5,906 Likes: 8
Posts: 5,906 Likes: 8 |
Click here for PDF version Original Spark Plug Listing
Posts: 1,019 Likes: 3
Posts: 1,019 Likes: 3 |
Hello Bill,
Could you tell me what the K-11 spark plug heat range might have been? I'm guessing they are no longer available, so what would you consider to be a good replacement for it?
I think that the R46 is the replacement for it - don't know the heat range.
Maybe someone else can chip in.
That would equal a 46. I use Ac 45 or Ac R45 in my 1939 and they work fine. If you do more highway driving the cooler #45 would have been recomended.
As per the list. The 1949 and 1950 used the AC 46-5, not the 44-5.
The heat range of the spark plug depends on the type of service that the engine recieves. Hotter plug for low speed use (higher number) cooler plug (lower number) for high speeds.
Posts: 2,037 Likes: 5
Posts: 2,037 Likes: 5 |
For us with less understanding about spark plugs
"46" really means... the "4" means that it is a 14 mm plug thread and the "6" equals the heat range. ( hotter than a "44")
"44" really means...the first "4" means that it is also a 14mm plug thread and the second "4" means that it is a cooler plug than a "46"
Am I close to right?
dtm
Posts: 1,896 Likes: 28
Posts: 1,896 Likes: 28 |
That is correct. So it follows a 86 AC plug would be 18MM and hotter than a 85. A 77 AC plug would be a 7/8" plug hotter than a 75. The late model AC part numbers do not follow this system.
