Posts: 1,125 |
Last year I bought a running 216 engine at a swap meet, and in addition to the plugs in the engine, there were also 5 AC M-8 spark plugs in a box. Was the AC M-8 the original plug for the 216? Sid
Posts: 7,046 Likes: 107
Posts: 7,046 Likes: 107 |
I believe the plug for the original 216 (1937) was an AC 46. That's the plug that my '38 left the factory with.
Posts: 828 Likes: 6
Posts: 828 Likes: 6 |
Yes the 41 to 48 came with the M-8 plugs.
Posts: 1,125 |
A friend gave me another set of M-8's. Both sets have insulators that are white with AC M-8 on them, but one set also has green stripes on the insulators. Which plug is the original, and which came out later? Sid
I believe the original plug was an AC 104.
Posts: 4,446 |
Posts: 1,125 |
The 1946-1948 came with the M-8. The 104 and 106 came in the 1941 and 1942 models. After 1948 the 104-106 was discontinued and the M-8, which was much improved, was sold for replacement in 1941-1942 models.
Posts: 1,125 |
Thanks guys. I appreciate the help. Sid
Posts: 765 |
The smooth plus with the M-8 I am of the understanding are the original plugs. The ringed plugs came out much later.
Member 45+ years, been around since the beginning !
The ribbed AC plugs were first used by Chevrolet in 1956. The M-8 ribbed version probably came along at that time also. The ribbs did two things. Helped to eleminate a spark running down the side of the plug and made a better seal for the boot that was used on all applications by that time.
Posts: 175 |
I believe the plug for the original 216 (1937) was an AC 46. That's the plug that my '38 left the factory with. The owners manual for 1937 lists the one year only plug as AC k-11
The plugs numbered 44, 45 46,etc. were new for 1938.
Thanks gents, I stand corrected.
Some time ago I put together a chart of spark plug types by year and model.
I don't guarantee it is 100% accurate but should be close.
Original plugs Year; Model; Type, Size & Line; Notes 1910-12; Whiting; A.L.A.M Auburn; 7/8” 2-piece 1912; Little 4; Standard AC; AC porcelain 1913-14; Little, C,L; Standard AC; AC-1 porcelain 1914; D,H; Long 7/8” AC; AC-1 porcelain 1914; H; Long 7/8” AC Titan; Non-sep. '14 style 1915; M-2,S-B-C; Reg. 7/8” AC CICO; Fancy AC Logo 1915-17; H,F; Long 7/8” AC Titan; Fancy AC Logo 1916-17; 490,M-2,3; Long 7/8” AC CICO; Fancy AC Logo 1916-17; S-B C; Long SAE AC Titan; Fancy AC Logo 1916-17; S-B D; Long Metric AC Titan; Fancy AC Logo 1918; S-B H; Long Metric AC Titan; AC letters 1918-19; FA,FB,D,S-BG; Long 7/8” AC Titan; AC letters 1918-19; 490; Long 7/8” AC CICO; AC letters 1920-25; All; 7/8” Long AC Titan; No. 78LT 1926-27; Series K, V, A; AC type B 1928; All; AC type Z 1929; All; AC G 1930; All; AC G-14, G-12 start (11/30) 1931; All; AC G-12 1932; All; AC G-12, G-10 start (3/32) 1933; All; K-9 1934; Master; K-10 1934; Standard; K-9 1935-37; ; K-11 1938-39; ; 46 1940; ; 44 1941-42; ; 104 1946-48; ; M8 1949-50; ; 44-5 1951-52; ; 46-5 1953-54; ; 44-5
S-B is Scripps Booth
You are invited to post this information under the Tech Talk thread.
If it could be posted as a table then it would be much easier to understand. Don't know how to get that done.
Posts: 5,906 Likes: 8
Posts: 5,906 Likes: 8 |
Posts: 1,125 |
Again, thanks guys. This web site is great! Sid
Good job Chip. This would be a cool list for us to expand by another 20 years or so.
But then maybe we should post it in the MEMBERS area (Resource Center).
Just a thought. Maybe others will want to join in on it.
The list is the standard plug for passenger and in most years 1/2 ton trucks. Taxis, delivery and other slow speed vehicles often used a hotter plug. An example is the 108 plug was used for the '41-'42 taxis, etc. Newer than 1954 gets more complicated as there generally were many more spark plugs used. I have a bunch of that information but never put it in the table. Hope everyone feels free to add to the list or make corrections.
