#25638 10/24/03 04:21 PM
looking at my '40 chevy parking light's ---the interior pc's ( socket etc. etc. ) are ugh!-ugh! ugly!!!!! question --can I buy chev of the 40's socket set (however they come w/turn signals)and elect not to use the turn signal wire ---with this you can see how little I know about wireing !thank's in advance for your help
john
#25639 10/24/03 05:33 PM
The 1940 parking lights originally came with a #63 bulb which is a single filament-single contact bulb.When it was equipped with the optional turn signals the socket was changed to a double contact socket-using a double filament 1154 bulb.That is the same bulb as used in the tail-stop light.If you would install a double contact socket in the parking light and it would require an 1154 bulb. You could use just the one contact-and filament that would be for the parking light.It would be the dimmer 3 candle power side of thee bulb.The 21 C.P. would have been used for the directionals-just don't connect it.
#25640 10/25/03 09:00 AM
Chevgene----------thank you ----that's the route I'll go (using the 21 c.p. bulb but not connecting it )
john
#25641 10/25/03 03:03 PM
Hi John...
I am also working on my parking lights. the 21 C.P. that is referred to...Is that a bulb number or a socket number, I don't seem to find it anywhere.
#25642 10/25/03 03:41 PM
The 21 Candle Power bulb refers to the light out put.If you use an 1154 bulb it has a 3 CP filament and a 21 CP filament.It requires a double contact socket as the bulb had two contact "buttons" on tne end.There is also a plain 21 CP bulb.It is a #1129 and has one contact--it will fit in the same socket as a #63 3 CP bulb--providing there is enough room for the larger glass globe.Check one of your tail lamp bulbs to see what an 1154 bulb looks like and look at the inside of its socket.The 1129 bulb has the same size glass globe as an 1154.
#25643 10/26/03 12:04 AM
bigbob,
just to add to gene's post, the #1154 is an "indexed" double-contact bayonet base...the index means that the little brass "ears" on the side of the bulb base are not aligned...one is closer to the bottom than the other...that way, the bulb goes in the correct orientation, so that the 3cp circuit (tail light) and the 21cp circuit (brake light) don't get reversed...
ok epi
#25644 10/26/03 02:38 AM
It all makes sense now.
