#256095 09/26/12 10:56 AM
My grandfather's 1968 GMC truck has been passed to me. I had the torn build sheet (from behind seat) reconstructed. The build sheet has numerous boxes with codes representing the equipment used to build the truck. Does anyone have a source the decipher these codes?
Thank You.
Become a Member!
Google - "1968 VIN, Cowl tag, GM option codes, GM RPO code" or you can list them here and maybe someone will help. The PRO codes rarely changed from year to year. I Googled the above address and I think you'll find what you need there.
I have a list of later model codes(GM Production Options) for passenger cars and light and medium trucks.
As Oldie said I doubt that the option codes changed a lot over the years.
If you would like to post some of the codes we will try to help.
Thank you for your responses...See list below.
Box # Box Title Code
1 Job Sequence Number 15876
2 Date Produced Blank
3 ? Key Blank
4 Comp Key Blank
5 Engine No Blank
6 Axle Number Blank
7 Transmission Number Blank
8 Carburetor Make Blank
9 Vehicle Ident. Number CM10D-ZB 15973
10 Sched. No. Date 10 01-10-68
11 Engine 360
12 Fan LA?L
13 Alter. 693
14 Engine Harness TEA
15 Accel Spring LGR95
16 Frame 5807
17 Axle YR
18 Wheel Carrier FRMSK
19 Rear Bumper ?--S
20 Exhaust BMDAJ
21 Radiator RI K
22 I.P. Harness TAP
23 Floor Plan 8F
24 Seq. No. 15622
25 Model CM15900
26 Carb. -123
27 V-Belt#1 VG
28 Alter. Pulley S --
29 Oil Filter Blank
30 Brkt. Asm. Gen. --
31 Front Spring --
32 Prop. Shaft BP ---- KZ
33 Prop. Shaft BP ---- KZ
34 Air Cleaner W-TG-
35 Rear Axle Shim ----
36 Grille Chrome
37 Cluster ?192
38 Dash ? Toe Panel AE
39 ? ?
40 Heater Air Cond. HTR
41 Radio PB
42 Trim GCC-1
43 Color LW UP W JTTL
44 Trans. Or TRF Case GL29B
45 V-Belt#2 UI
46 Power Strg. Pulley DB
47 Starter 7375
48 ? CC-AA
49 Rear Spring GB---
50 Prop. Shaft Hanger? FA--
51 Stg. Gear L
52 Rad. Hose UPR-LWR KT SC
53 Battery Y59
54 Fron End Harn. TCG
55 Look Equip. AB
56 Trans. Cover CBA-
57 Tire Brand --
58 Wheels Frt RR SP ---AZ4AZ
59 Wheels Frt RR SP ---AZ4AZ
60 Spec. Order Blank
61 Cooler Lines EDCCB
62 V-Belt#3 --
63 C/Shaft Pulley ??GC
64 Batt. Neg. Cable 1231
65 Batt. Neg. Cable 1890
66 Fuel Filter Blank
67 Front Shock VK
68 Trans. Ctl. Lvr. CF--F
69 C/Case Vent Hose --VGE
70 Hub Caps TC-
71 Speedo. Cables AJ --
72 Platform WOOD
73 Lights & Refl. ?1
74 Front Tires AE
75 Rear Tires 2 AE
76 Spare Tire AE
77 Export Prep. --
78 Top ?
79 ? CU
80 V-Belt#4 Blank
81 Speed. Gear 34-01
82 Ign. Coil 161?
83 Blank MGLVA
84 Frt. Suspension HA AA
85 Rear Shock RJ
86 Tail Frt. Wire 1433
87 Tail RR. Wire 5633
88 Brakes SC D
89 Heater Hoses HR BA
90 Ext. Moldings -AAAA
91 Tools AHAA
92 Mirrors -AAT
93 Floor Map BBS??
94 G.V.W. ?
95 ? ?
96 Order Number 5858
97 Zone 36
98 Dealer 285
99 Class Blank
100 Ship to - Tag Blank
101 Ship to - Zone Blank
102 Ship to - Dealer Blank
103 Charged to Grant County Motors 425 West Main John Day Ore.
104 Shipped to Blank
105 S/F Blank
106 Date Shipped Blank
107 Routing 11
108 Car & Load Number Blank
109 Destination Charges Blank
110 Plant To Destination Amount Blank
Blank Trim Blank
Blank Paint 35
Blank Vehicle Ident. CM10D-28
Blank Number Blank
Blank Carb. Blank
Blank Engine Number 351E
Blank Axle Number SP44 354
Blank Date Blank
Blank Trans. Number 435GL
Blank Options Blank
*A10 Panoramic RR WDW
A11 Tinted Wind All
B98 Side Trim Mouldng
*D32 LH Short Arm Mir
*D34 RH Short Arm Mir
D89 Paint Stripe
E81 Floor Board EQ
G50 HD Rear Springs
J04 RR Axle-354 Ratio
J70 Vac Brake Booster
L23 V6 Eng-351E
M25 4 Speed Trans
N40 Hydraulic Strg
P03 Chrome Hub Cups
R44 F700X15X6 N T
R44 R700X15X6 N T
R44 S700X15X6 N T
U63 Pushbotton Radio
V21 Chrome Grille
V37 Chrome Front Bumper
V43 RR Step Bumper
Z53 Amp-Oil-Tem Gauge
Z63 Custom C&C Equip
535 Ivory/Dk Grn
603 Green Cloth Trim
I guess I was wrong, very few of the production codes you have listed correspond with the code books that I have, however the items that you have listed describes what options were installed on the truck, example U63 was the standard AM radio that was installed in most vehicles.
Sorry
