#255933 09/24/12 10:48 PM
1922c Offline OP
I changed the coil and the rest to to 12 volts. The spark is so strong it arks all over in the dist. cap..New cap and rotor
It back fires through carb. and exhaust..what have I done???
1922c #255937 09/24/12 11:10 PM
Maybe you should have a dropping resistor between the battery and the pos. terminal on the coil. Maybe you messed up something with the 12 volts?
1922c #255942 09/24/12 11:44 PM
Most 12volt point systems used a dropping resistor so there was only 6volts on the points. The resistor cuts the voltage in 1/2 at the coil and distributor cap also.
1922c #255955 09/25/12 02:52 AM
Have you considered reverting back to the correct 6-volts?
devil Agrin
1922c Offline OP
Thanks for the information. The ballast resister and a few twiks put it back on the road.
