#253813 09/03/12 06:25 PM
VCCA13 Offline OP
I am working on the side mount brackets for my 31 sedan. These are pictured on page 4 of FS catalog, p/n GM1022K. I want to dis-assemble the side mount rods so I can clean and paint them. How is the short rod attached to the socket? Is it threaded, pressed or pinned? It looks like the short rod locks the long rod in place in the socket.
VCCA13 #253832 09/03/12 08:33 PM
Yes, the short rod screws into the side of the coupling piece at an angle and tightens into a groove in the longer rod at a set location. The operating length of both rods is set by the double bolts at the ends (one secured under fender, the other under dash.
VCCA13 Offline OP
Thanks much. Now I can put the pipe wrench to it.
VCCA13 #253907 09/04/12 02:27 PM
No! At least soak it for a week or too. Al W.
It's Wise to choose a six!
VCCA13 #253915 09/04/12 03:24 PM
NO! A pipe wrench will do more damage then good.
32 Confederate
Bruce S. DeFord
VCCA Judging Committee Chair
A pipe wrench will really mess it up. I had new hardware made in stainless steel, won't rust and looks good. I do have an extra repro if you need it.
karl
karl31 #253941 09/04/12 07:10 PM
VCCA13 Offline OP
Thanks, guys. I was kidding about the pipe wrench. They have been soaking in Kriol for two days now. Will fire up the propane torch in a day or two.
VCCA13 #253952 09/04/12 08:53 PM
Phew! That was too close!! Al W.
iagree
32 Confederate
Bruce S. DeFord
