Posts: 150 |
Hi. Does anyone know how to get the belt wheel off the crankshaft on a 490 1919? Olle
Posts: 2,418 |
I think Per-Ã…ke Larsson will be able to reply. Here is the adress in Sweden: per-ake.larsson@telia.com. Why not become a member of VCCA, the sooner the better? You can join and pay through net bank on these pages.
Solan G, # 32797
Posts: 3,192 Likes: 8
Posts: 3,192 Likes: 8 |
You will need to fabricate a puller from flat bar with bends in the ends , and a hole with a thread for a bolt with a length of 9 1/4" . BOLT should have a tapered point.
The flat bar would need to be approx 1/2 thick. The width on the inside needs to be 4 1/4" inside. The second bend in the end needs to be 1 1/4" inside to create a " square J " in the end. As the pulley is VEE form you will also need to taper the inside of the last 2 bends so that they will fit the inside taper of the pulley where the fan belt sits. Wind the centre bolt with a spanner , to remove the pulley which is a pressed on fit.
JACK
Posts: 173 |
Wouldn't a bearing race puller work that is thin enough to slide behind the pulley and then connect a H style puller to the bearing race puller that has a center bolt to pull the pulley off? These tools are readily available so you don't have to make anything.
Cheers, Gary
Posts: 150 |
Thanks. I pulled the wheel yesterday, no problem with an ordinary tolegged puller. Olle
