#252547 08/18/12 08:55 PM
lilrobo Offline OP
update
i flushed it 2 times completely ,then i started with clean water and i added a bottle peak flush kit ( that's whats in it now ) run the car to town and around a bit stopping at red lights then came home and let it run in drive way while i cleaned it ( 20 min ) and it just got to have way,, could i have had too much antifreeze ? , would being too strong hurt me ?? that's weird.. so i might run it to town this evening while we get dinner and see what it does ,, we got back seems like everything is great now , either it was me flushing it or the mixture,, or i had air trapped something is different now ,,ran all day lights and all barley got to halfway ,, i like it !!
thanks
Wilwood Engineering1955-1957
lilrobo #252664 08/20/12 12:19 AM
If you run 100% antifreeze you will not get the cooling needed. 50% is the maximum unless you live in Alaska or N. Colda.
Chipper #252672 08/20/12 07:01 AM
lilrobo Offline OP
i should have known this just forgot after all these years of not doing antifrezze my other car i really do anything it just check it thats it
i got it 50/50 now everything has been fine so far ,, but i think the overhaul is coming sooner than later the noise is getting more and more ,, i am starting to look for over haul kits , i dread it
thanks
