#252211 08/15/12 12:38 PM
lilrobo Offline OP
what would happen if i just installed a power brake booster and split the front and back lines , right now i have just 1 line coming from my cylinder, and leave the shoes for now ????
thanks
Wilwood Engineering1955-1957
lilrobo #252218 08/15/12 02:52 PM
DFC Offline
lilrobo, we know you like to 'mess with your '58 but for your sake and all the folks and objects on the road in front of you-----please don't try to re-engineer the brakes!! 1967 was the first year for federally mandated separation of front/rear brakes. Up till then about 100 million cars & trucks were made with the old combined system and properly maintained they work fine. A properly designed 'hotrod' aftermarket split system with front discs is over $1000. repairing the old one can be done for about $300 if your drums are ok to resurface.
Dan
DFC #252241 08/15/12 06:46 PM
lilrobo Offline OP
good point ,, thanks
i was just asking cause my sons 65 stang has got power brakes with shoes we did the disc in front with 17" rotors and w had to use a diverter valve to adjust the pressure so that the lock didnt happen , but i taking the drums off and inspecting them and checking them out might just need cleaned up and adjusted
thanks again , i do like playing with thing gives me something to do
