Just a quick question regarding the type of grease most of you are using in the distributor grease cups. Would a multi chassis lube work? I know I have a "special" grease that is used in the water pump that seems to have a more waxy look to it but I am not thinking this is used in the dist.
Thanks!
John
John Lanning
I use cup grease or wheel bearing grease.
thanks for the information .... just wanted to confirm before finishing up on a distrubutor rebuild.
John
John Lanning
