whitmoy Offline OP
I have a 30 Chevy 4 door sedan recently pulled out of 15 years in storage in a garage. I pulled the starter while checking another problem and discovered the bottom (?) half of the flywheel area is packed solid, and I do mean SOLID, with dogfood. Obviously I stumbled onto the food cache for the previous owners mice. Any ideas on how to clean this stuff out of there ? The shop vac will only reach so far.
How about duct-taping some small diameter hose or tubing to the end of your shop vac hose?
Or, you could buy a very small, hungry dog. Good luck!
1936 Low Cab Pickup
Did you try removing the sheet metal cover at the bottom of the flywheel to gain access to the lower area of the flywheel?
JYD is only providing advice because he wants the dog food when you get it out of there!
All the Best,
Chip
"It's wise to choose a SIX"
whitmoy Offline OP
Thanks Dog ! I'll put the face shield on, line up the barn cats, crawl under there and see what happens !
These mice were particular... they put the dogfood in the flywheel area and the rear seat cushion stuffing in the exhaust pipe & muffler ! didn't want to mix things up !!
when i got my 30 yrs ago it too was packed with mice stuff in the flywheel area. i saw what i thought was clutch lining flaking off looking thur the timing hole. i did pull the trans to replace the clutch and cleaned out the area. i guess those mice love that place to call home.
That's just another reason to buy a set of those after market rubber bell housing timing hole covers that were talked about while back in a post...they are sold by a few of the usual old Chevy parts suppliers.
I would only use them if the car was being stored away for awhile, (as a mouse deterrent) don't use them on a "driver" clutch needs air circulation.....ED
whitmoy Offline OP
I thought my clutch was coming apart also ! Thanks for the tip on the timing hole cover, especially only for storage. This afternoon I'm pulling the bottom cover , hope to get it all cleaned out.
