Chris,
I checked your old posts and see that you have an oil bath air cleaner. Here is what I found about decals and placement on the air cleaner. Looks like the same oil bath decal was used on all years of AD trucks.
I've posted some of these pics previously. Hope I'm not boring those who have already seen them.
> Original Pic, Chevrolet documents
![[Linked Image from i149.photobucket.com]](http://i149.photobucket.com/albums/s50/lonnieinorlando/54%20Chevy%203100/Carburetor/AirCleaner1946oilbath.jpg)
This
press-on decal from the Filling Station seems to best match the decal shown on original pics of oil bath air cleaners. The "AC" logo is white. The other areas that appear white are actually clear, so they look black when the black air cleaner shows through. The spacing and style of the letters and borders appear to match the pics of the original decal.
> Here is the Filling Station decal freshly attached to the newly painted RPO 216D air cleaner on my '54 3100.
> Here is a close up.
![[Linked Image from i149.photobucket.com]](http://i149.photobucket.com/albums/s50/lonnieinorlando/54%20Chevy%203100/Carburetor/NewDecalcloseup-600.jpg)
Tips:
> Trim the edges of the decal close to the red border, but do not cut into the border. This reduces the amount of the low gloss clear edge that will be against your black air cleaner that will probably be glossier. A straight edge and razor blade work better than scissors. I used scissors
> Clean ALL the dust off of the air cleaner where the decal will attach.
> Use the pics of original air cleaners for placement of the decal.
> Use a toothpic or other item to gently press against any small air pockets, especially in the clear areas where the black air cleaner shows through. Those areas should look uniformly black. I also used a pencil rubber eraser to press out air pockets.
Decals that didn't work:
> The Packard Club Internet Store
1937-47 Oil Bath Air Cleaner (All) (Water Transfer) = $5.00 (This item may be out of stock)
![[Linked Image from i149.photobucket.com]](http://i149.photobucket.com/albums/s50/lonnieinorlando/54%20Chevy%203100/Carburetor/Aircleanerdecal37-47Packardclub-orgDE-10.jpg)
This decal is thin, laid onto my air cleaner well, and was my first choice until ... After I attached it, I saw that it was printed wrong. The "AC" logo that looked white against the backing paper was actually clear. So the "AC" looked black when attached to the air cleaner.
![[Linked Image from i149.photobucket.com]](http://i149.photobucket.com/albums/s50/lonnieinorlando/54%20Chevy%203100/Carburetor/PackardDecal-BlackAC-600.jpg)
Classic Parts and
Chevs of the 40'sJust as the Packard decal, the "AC" logo was clear, so it looked black when attached to the black air cleaner. The top and bottom stripes are blue instead of black. That is the decal on my air cleaner in the photo in my signature line taken before I replaced the decal with the Filling Station decal.
Jim Carter Truck Parts decal was totally different to the pics of the original air cleaner decal. Perhaps it was copied from an earlier model(?)
Good luck with your air cleaner. No info about your oil filter.
- Lonnie
