Posts: 1,069 Likes: 9
Posts: 1,069 Likes: 9 |
During my rewire, I had to swap the wires to the gas gage so it would register. The gage is on as soon as I connect the battery. Don't remember, but think the gage should go on when you turn the key on and go to empty when you turn the key off. Can you check your gages and advise? Thanks.
Posts: 1,135 |
During my rewire, I had to swap the wires to the gas gage so it would register. The gage is on as soon as I connect the battery. Don't remember, but think the gage should go on when you turn the key on and go to empty when you turn the key off. Can you check your gages and advise? Thanks. Keith....That what my 38 Master coupe does...Gauge goes to empty when key is off...ED
Posts: 2,433 |
JYD and ED have it right. Key off.....gage off. Key on....gage on.
That's how my 48 works.
ken48 VCCA 42589
That's what I thought. Will need to check it out in the next couple of days.
Took a look at how I wired the ignition switch and found it was wrong. Rewired per YNZ instructions and looks like everything is working correctly for now.
Posts: 2,433 |
Love it when a plan comes together ![ok ok](/images/graemlins/default/thumbsok2.gif)
ken48 VCCA 42589
